Page 3 of 6 FirstFirst 12345 ... LastLast
Results 21 to 30 of 60
Thread: Is there a Fuchs Tutorial?
  1. #21
    Senior Member ghalperin's Avatar
    Apr 2014
    Newport Heights, CA
    Center caps
    I picked 2 pairs of 15x6 wheels as a set of 4.
    The first pair are dated 373, 911 361 020 00, ~6mm wide lip around hub, 66mm center
    Name:  IMG_4390 (Small).JPG
    The second pair are dated 974, 911 361 020 10, ~4mm wide lip around hub, 71mm center
    Name:  IMG_4391 (Small).JPG
    The set came with 3 prong caps
    Name:  016 (Small).JPG
    Name:  017 (Small).JPG
    What are the correct caps for the later wheels? I know that they are the ring type, but holes or no holes for the removal tool?
    Did any of the 3 prong caps have holes?
    Glenn Halperin
    Early 911S Registry Member #2956
  2. #22
    Aug 2009
    SF Bay Area
    The later wheels (some time in 1973, mostly for 74 YM cars) came with ring type hubcaps. The original caps did not have holes in them.
    they were discontinued by Porsche many years ago and replaced with ones with holes. If you can find a couple of caps with no holes, you can put that set of wheels on your car and nobody will notice that the wheels don't match. One second thought, put the 2 late wheels on one side and the early ones on the other side. That way, nobody will be able to nitpic your wheels
    Jim
  3. #23
    May 2011
    Chelsea, Québec
    some history from the company themselves: http://www.fuchsfelge.de/index.php?id=4&L=1
    Member #1616
  4. #24
    May 2011
    Chelsea, Québec
    and a video of the production process: http://www.fuchsfelge.de/index.php?id=718&L=1#c5076
    Member #1616
  5. #25
    Registry Member #2679 friggens's Avatar
    Jul 2013
    Albuquerque, NM
    Awesome thread. Subscribed...
  6. #26
    Senior Member moito's Avatar
    May 2013
    AUSTRIA (tu felix)
    just noticed that the rim on post #7 is a prototype with different horn....similar to the rim that was sold in ladenburg auction last weekend.
  7. #27
    Very good info here !!
  8. #28
    May 2005
    Oroville, CA
    The gold anodized wheel is a standard early 6X15. That is a reflection, not a different profile. I have seen them use gold anodizing used in other presentation wheel parts.
    As I remember, that was the meeting when they were discussing the reason that the early profile didn't lend itself to any more widening. Thus the cut away piece showing the drop center had to be moved outward and required the shorter spokes so there wouldn't be any interference. From this meeting was the birth of the late (flat) 6 wheel to accommodate the close drop center and being able to make the 7-11 widths.
    H
  9. #29
    May 2013
    AUSTRIA (tu felix)
    Quote Originally Posted by Harvey Weidman View Post
    H
    Mea culpa! Mea culpa!
    i think i need a bigger screen
    or get my eyes checked ...
  10. #30
    Apr 2011
    N.Calif., south of SF
    From the Otto Fuchs company web site-
    We give form and function to high performance materials
    The superior properties of forged alloy wheels as compared to cast ones result from the applied material.
    The OTTO FUCHS forging material, a forging alloy with at least 95% aluminium , is far superior to any cast material with respect to strength and ductility. Reduced wall-thickness and weight reduction are the result of the combination of best materials and most modern manufacturing and simulation techniques. Not least: In extreme driving situations the forged aluminium wheels offer greater safety margins than cast wheels.
    Another important advantage of forged alloys is the feasibility of polishing: the dense microstructure without porosity and the low silicon content are not only responsible for the superior mechanical properties but also allow for high gloss polish of the wheel surface . Also in this regard forged wheels are setting the standards!
    Strength- / Tensile test
    The following pictures show a tensile test to prove the material properties of the used alloy.
    <dl class="csc-textpic-image csc-textpic-firstcol" style="margin-right: 10px; margin-bottom: 10px; display: inline; float: left; width: 208px; margin-left: 0px !important;"><dt style="margin: 0px; padding: 0px; display: inline; float: none;"></dt><dd class="csc-textpic-caption" style="margin: 0px; padding: 0px; float: none;">sample before tests
    </dd></dl><dl class="csc-textpic-image csc-textpic-lastcol" style="margin-bottom: 10px; margin-left: 0px; display: inline; float: left; width: 208px; margin-right: 0px !important;"><dt style="margin: 0px; padding: 0px; display: inline; float: none;"></dt><dd class="csc-textpic-caption" style="margin: 0px; padding: 0px; float: none;">sample after tests</dd></dl>
    The sample on the left side (on each picture) was taken from a forged aluminium wheel and the sample on the right side was taken from a cast aluminium wheel.
    The sample of the cast wheel breaks quicker.
    The reason: Cast wheels have a lower tensile strength and - especially - a lower elongation.
    Haasman
    Registry #2489
    R Gruppe #722
    65 911 #302580
    70 914-6 #9140431874
    73 911s #9113300709
