Thread: What Era Is This Fuel Tank From ?
    Aug 2011
    north of the 49th parallel On Can.
    Normal looking early tank from the top side has a dated 12/72 sending unit that could or not be original.
    Now the backside has 3 openings in the center of the tank like 69-73 but different 1 only threaded for supply a small tube center for vent I guess the third larger tube I will guess is return.
    But the dam thing has a brass Benzin plug that I thought was only used on 74 and later 911 gas tanks.
    You tell me ?
    Thanks for any info
    HOPPER
    Aug 2009
    SF Bay Area
    It is a 73 1/2 911T CIS tank.
    Jim
    Aug 2011
    I thought you would know & answer thanks Jim. So would this be a half year only gas tank?
    I thought 74 911 gas tanks started with the space saver spare tire (smaller tire area on tank) also started with the bottom drain plug. That what was throwing me off.
    Hopper
    Aug 2009
    SF Bay Area
    Quote Originally Posted by hopper View Post
    Hopper
    Yes, it is a "half year" only tank and only for 911Ts. 74 and later tanks have approximately 5 gals more capacity, but you already knew that.
    Jim
    Jan 2011
    DFW TX
    The bottom plug houses the fuel strainer sock in the swirl pot. The large hole on the rear is the drain plug. The other two are supply and return.
