Dealer for Cibie & other period lights, Corbeau Seats, Maxilite Replica Wheels!
Greg Gear Head Facebook
http://greggearhead.com/index.html
http://www.ebay.com/sch/greggearhead...p2047675.l2562
http://www.thesamba.com/vw/classifie...e=greggearhead
Hi, yes, they are factory ones.
The flywheel, when in doubt, has even factory part numbers.
The pressure plate it'is for 911/01 or early 915 gears.
Sachs produces it even nowadays, but the central part is entirely made of steel (and of course heavier), not only the contact surface.
In pic #5 you can notice the typical 911/01 release bearing, so it was on a <71 car.
This is a new one:
Awesome - thank you. I've heard it is an RSR clutch - any way to verify?
Any idea on values?
Hard to say, depends on if it's still useable and for how long..
The flywheel could be Rsr but if you find all the clutch togheter, it was probably on a 2.2 (race?) engine.
That bearing doesn't fit a RSR 915 gear.
Do you have to sell it?
It came from a working vintage race 911- not sure how much life left.
I don't have to sell it, but don't need it.
That is not an RSR pressure plate from what I can tell. Here's why:
1) The spring diaphragm does not appear to be heavy enough (heavy convex) ... although, it's pretty tough to tell from the photos
2) The T/O bearing is for a 901
However, the pressure plate does appear to be the lightweight, all aluminum ones occasionally found in 70/71 Ts and Es.
The ring gear DOES appear to be the lightened RSR-type, but I have a factory RSR clutch in my car and it's been my experience that the RSR ring gear will only work on an RSR pressure plate (I've tried swapping it around and it didn't fit properly). So, the ring gear MAY be a copy, albeit a good one.
The flywheel looks to be a factory race part.
Either way, you've got a good bit of kit there. You'd be doing well to put that behind a hot 2.8L ... instant RPM.
-Marco
TLG Auto: Website
From what i see:
Flywheel is machined lightweight from standard
Starter gear could also be machined from standard
Throwout bearing is standard 911 (not 915, not 901)
Clutch is standard 911 and perhaps early 915
