Results 1 to 10 of 10
Thread: Original RS door panel hardware question
    Hi guys. Looking to find some photos of original RS or a lightweight door panels that show exactly what the original hardware look like. Specifically looking for the screws around the perimeter and the screw that holds the leather strap to the door face
    Thanks for any help you can give
    1974 911"S" - Silver
    10 sec 67 VW
    Early "S" Registry #439
    RS M471,M491 panel
    First, photo of white car is 9113601382, RS (no conversion), and second set, orange car is 9113601008, RSR M491 conversion. If I remember correctly, the large Pan head phillips that holds the front end of the pull strap is a machine screw, the other end, inside the door attaches with a round key chain split ring. The outer perimeter screws are nickel or chrome phillips countersunk oval, with a profile under the head, in 1974 the same screws changed to black, notice the 2 sizes of trim on the top edge, the joint is at the vent window post. the Fiat handles use a black countersunk oval head phillips screw. Hope this helps, If anyone has anything different let us know, I've chosen 2 cars which I think are good examples.
    Ernie W
    member of Early 911S Registry
    Quote Originally Posted by Ernie W View Post
    these are fantastic, as usual Ernie. thanks!
    keith
    r gruppe # 436
    Senior Member dirk07's Avatar
    Apr 2016
    Stuttgart, Germany
    closer pictures of the screws (RSH 1256)
Size:  57.4 KBName:  pd5_7137.jpg
    btw: while the white one (1382) doesn´t show a black painting on the inner door around the trim panel the converted red (1008) shows
    Any idea about the dimensions of the strap itself (cross-section)?
    keith
    r gruppe # 436
    Aug 2006
    Chicago area
    Dave, I think you can use collared interior screws and be darn close to the original. The leather strap screw is just a pan head phillips.
    Scott H.
    1969 Coupe LtWt
    1973.5 911T
    Thank you to all who responded. I really appreciate it.
    It appears to me that the front of the strap used the existing arm-rest threaded hole. Is that correct?
    10 sec 67 VW
    Quote Originally Posted by Cornpanzer View Post
    That's what Aaron and I were thinking as well, when we looked at a bare door yesterday. I bet that's right.
    keith
    r gruppe # 436
    Apr 2016
    Stuttgart, Germany
    +1 arm-rest
    Aug 2006
    Chicago area
    That's how it is on my car, Dave.
    Scott H.
    1969 Coupe LtWt
    1973.5 911T
