Thread: 1965 911 trans typ 902/0
    1965 911 trans typ 902/0. This is a 4 speed 911 trans dated 31st week of
    65. $1700.
    Transmission number 160496
    Physics Guy oscillon's Avatar
    Sep 2010
    Washington DC
    Pretty sure you didn't get a 4-speed in a 911 from 65-66. That's most likely a 912 trans.
    ______________________________________________
    Dan B.
    1966 911 black/red
    1966 912 slate grey
    1996 993 black/tan
    Pretty sure you are guessing wrong. According to the Porsche Technical Specifications Book, page 62, shows 911 trans numbers 160001 to 162462 up to July 26 1965. A 912 would have serial number 163001 to 165214. The ratios are:
    11:34; 19:32; 24:27; 28:24 w/ 7:31 ring and Pinion. This info is also backed up by the Blue Sky Motorsports website that rebuilds Porsche transmissions. "The transmission was designed as a 5-speed however 4-speed versions were offered. The shift pattern is considered to be odd with reverse at the top left and first on the bottom left. This makes for a more difficult 1st to 2nd up-shift." This is why many opted for the 4 speed "H" pattern.
    Mar 2004
    Castro Valley, Ca.
    history ...?
    1940 Mercury town sedan
    Tom, that goes against my database. I had the same in my charts, but that goes against actual installation. As Dan says: no 4-speed in a 911 from 65-66.
    160001 to 162462 was 1966 912, and 163001 to 165214 was 1967 912. 200001 to 200402 was 1967 911. So 16xxxx for 1.6L 912 and 20xxxx for 2.0L 911
Tags for this Thread
