Results 1 to 7 of 7
Thread: Seal at front engine compartment & Body ?
    Guys
    Found this seal ( see photos) Name:  C864501D-21B0-413F-9718-323B5EA51A04.jpg
Size:  40.5 KBName:  00C70EDB-B6A5-4A27-9248-64C132B3CC97.jpg
Size:  65.4 KBName:  93F4DF4E-1488-4229-B832-2BBC9566C473.jpg
Size:  61.2 KBbetween the front engine compartment wall and the edge of cross over metal.
    It’s a heavy vinyl/rubber material with a foam type insert, just wedges in the gap
    Searched the parts book and can’t find a part number.
    Where to get or make ?
    Thanks for assistance
    Frank
    73.5 Snrf T
    71 Snrf T
    70S targa
    76 914 2.0
    82 Targa,
    85 Alfa GTV6
    60 Lancia Appia Zagato GTE
    36 year PCA member
    Dec 2012
    Denver Co.
    Quote Originally Posted by 71gold View Post
    Guys
    Frank
    I believe that goes in between the crossmember and the firewall. Try going to AVECO. a major supplier to manufactures and restoration shops. They have a huge selection of generic rubber products and seals.
    I fabricated a duplicate thin wall rubber tubing and foam cord....both at McMaster Carr.
    Mark Smedley
    '59 VW Typ I
    '69 911T 2.7
    '86 930
    '04 GT3
    '16 Boxster GTS
    Sep 2009
    I used a bicycle inner tube.
    Quote Originally Posted by stretch View Post
    I've tried that in the past in various spots...bicycle inner tubing turns to powder in a year or so.
    Look for some EPDM or Viton tubing.
    Mark Smedley
    '59 VW Typ I
    '69 911T 2.7
    '86 930
    '04 GT3
    '16 Boxster GTS
    Guys...
    Excellent comments .....
    Thought I would need to fabricate.
    Think EPDM type like the single sheet roofing material used with gravel ballast ...think will be my choice.
    Odd detail for Porsche .....must have wanted separation from engine vibrations,heat and noise .
    I know it’s on my 70 as well. What other years and when did they change ?
    73.5 Snrf T
    71 Snrf T
    70S targa
    76 914 2.0
    82 Targa,
    85 Alfa GTV6
    Senior Member moito's Avatar
    AUSTRIA (tu felix)
    Guys...
    i`d say its more of an "unwanted air flow" seal like the ones surrounding the engine..
    several versions out there
