Page 1 of 3 123 LastLast
Results 1 to 10 of 24
Thread: Bent trailing arm
    Bent trailing arm
    sent newly restored 72S for final suspension set up. report back is that one of the rear trailing arms is bent.
    can they be straightened? and if so, how?
    thanks for any tips!!
    Jul 2017
    Glendora california
    I have a set for sale from my 72 t. $550 obo for the pair
    thanks Todd, am in the UK so probably too expensive to buy and ship vs straighten. If i find i cant straighten, i will get back in touch.
    Andrew
    Nov 2010
    Port St Lucie FL
    Frank would know (yes, that Frank!)
    My trailing arm was bent after a trailering accident and he found me a replacement after a while. I would think he would have straightened it if he could have because it was hard to find one. Hope this helps.
    Senior Member Cliff's Avatar
    Mar 2006
    8903one
    My guess would be , yes. If it is just slightly askew, it might adjust back to spec. I would contac a Porsche dealer as they may have a go-no- go fixture to check it. I have often wondered if this would be easy to have done ( someone with the fixture, tool ) or are all the old tools/ gages no longer around. Hope you have a good outcome. ....cliff
    —Juan Manuel Fangio[48]
    ”What would PORSCHE do”
    Quote Originally Posted by Cliff View Post
    I know if no one who has successfully straightened a bent trailing arm. Come to think of it, I know no one that has attempted it.
    Regards.
    Mar 2006
    8903one
    I was trying to be optimistic. My bigger question, is there a gage to determine if a trailing arm is out of wack before installation?......cliff
    Yes, there are factory jigs that are used to check trueness. The jigs weigh a ton and are very bulky. I used to have all of them.
    P 295 for SWB
    P 295b for LWB
    Jon B.
    Vista, CA
    Jun 2012
    London, Ontario, Canada
    Long before there was “an App for that”, there was “a jig for that”. Amazing.
    Early 911S Registry # 2395
