Results 1 to 10 of 11
Thread: Speedo Angle Drive Set Screw into Transmission with Broken Helicoil
    Feb 2003
    Los Angeles
    I was working to replace the original Speedo Angle Drive unit on my 1970 911T, which was giving me a clicking noise independent of the speedo cable.
    The set screw above the angle drive was loosened to release the angle drive unit. But the set screw was wiggling in it's threads as I was loosening it, which felt weird.
    When I went to re-install the set screw, I realized that the set screw threads had a helicoil in the transmission case that had broken free of the case. Note the red Loctite. See the photos below.
    Is there supposed to be a helicoil in the transmission case in this area or was this area repaired by a previous mechanic?
    The transmission was rebuilt about 10 years ago.
    Anyone else have this problem?
    Thanks,
    Bert Jayasekera
    1970 911T - Tangerine Orange
    Early 911S Registry #494
    R Gruppe #167
    I think a properly installed heli-coil will work for you, obviously that one wasn't correctly done. I don't think it was originally inserted because I know I have had to install inserts to fix those threads. You also need to get that throttle boot over the throttle link,,,
    May 2011
    Chelsea, Québec
    Great catch!
    Member #1616
    Nov 2009
    Cecil pa
    Quote Originally Posted by Bert View Post
    With enough thickness in that spot, a careful tap of 15% larger pitch might alleviate the helicoil.
    Feb 2003
    Los Angeles
    Thanks Ed. Can you recommend a more permanent solution, if I remove the transmission nose cone to do the repair?
    Good catch on the throttle boot. Can anyone provide a photo for the correct boot position?
    Bert Jayasekera
    R Gruppe #167
    Feb 2003
    Los Angeles
    Quote Originally Posted by 62S-R-S View Post
    I like this idea, but the factory bolt has a specific tip to set against the angle drive unit.
    Thanks,
    Bert Jayasekera
    R Gruppe #167
    Feb 2003
    Los Angeles
    Thanks,
    I meant set screw for factory bolt.
    Bert Jayasekera
    R Gruppe #167
    Take off link, spread boot over small end, reinstall
    Nov 2009
    Cecil pa
    Yes. The phrase 'nothing is easy' is a favorite...more hassle would be a metal insert plug to receive a new drill and tap for the screw.
    A time-zert works just as well.
