Results 1 to 10 of 14
Thread: SWB Dash Radio Cut-Out Repair?
    Recently picked up a sweet little '66 Gulf Blue 912 from a fellow member. Car has lots of original touches but, unfortunately, someone did this to it:
    That radio has to go and I have a correct, W-series Frankfurt on standby.
    I've done the same job on a LWB dash and many vendors are selling those parts but I'm having trouble locating what I need for a SWB car. Can anyone point me in the right direction?
    Jul 2011
    Chicago Area
    Are you wanting results like this?
    Mike Fitton # 2071
    2018 911S Carrera White
    Exactly, Mike. I see Stoddard has the entire dash trim set. Wondering if that's my only option? And if I need any other parts?
    Sep 2009
    COPENHAGEN, DENMARK
    I have been making the dash facia sets for years ,
    as the only one making a correct one for each year 66.67.68 yes they are different :-)
    Problem is you most likely need to weld in a metal plate in the dash it self
    as the brushed alloy trim is so thin, it will not hold the radio it self
    but do note if you only change the center piece there will be a difference due to the sun etc
    or you can delete the radio and use a radio delete cover, but doubt it will cover the hole
    but they are on stock for all years , at 120 EURO + 20 EURO postage to US ,
    can post pics later if you are interested
    Marek
    Please, Marek. Is $120 euro for the full set? Or just the piece I need?
    Aug 2016
    NE Ohio
    subscribed
    May 2011
    Chelsea, Québec
    For my wood trimmed '66 dash, I bought a period set from Adam (unobtanium) and had the dash rewelded so that it is strong enough to take the weight of the radio. I did consider the radio delete plate, but as the car came with a radio, I decided to go the more expensive route. The only issue was grinding down the weld afterwards ensuring that it didn't damage the integrity of the VIN...
    I had to do a couple of minor repairs to the wood trim, but, it all looks splendid now.
    I appreciate the 912 is a different trim, but the principal holds good...
    Member #1616
    Virginia Beach Va
    I had the same problem with my dash being cut out I had my metal shop guy fix it with the skills he has it was expensive.
    Covered it completely like the whole was not even there then took a pattern to make the new cut .
    My first thought before I bit the big buck bullet . Woody radio sells a stainless support plate that could be tacked in from the back or fit it has the correct profile I was going. TO go that route check it out
    https://www.woodyscustomshop.com/
    Doug Lehman
    Member #2825
    1966 912
    1978 911SC Targa fun in the sun
    Nov 2008
    Finland
    Quote Originally Posted by Marek View Post
    Marek
    Marek,
    I'm just about to order your set but I was looking this just couple of days ago and which one to order; I have fairly early 66' 912 and very early 67' 911 and they seems to have exactly same brushed aluminium trim when I compared these (material finish). I need this for 67' so correct one I should order is 66' one so brushed aluminium? (brushed, not polished)
    Thanks!!
    - Ville -
    1967 911 Slate Grey/red, fully restored + 66' "r-ish" hotrod project
    Quote Originally Posted by Will 1967 View Post
    Marek,
    Thanks!!
    Is there a website to compare Marek's parts and order?
