Removing Throttle Body Nuts - Need Help
I am sending in my throttle bodies to Eurometrix (to Matt) to have them rebuilt. I have successfully removed the right side Throttle Body and have 5 of the 6 nuts removed for the driver's side (left side). I cannot get a 12 mm socket or a 12 mm wrench on the rear most nut (closest to the engine shroud for the fan. Can anyone help? Is there a special tool I need?
Thanks in advance for your time.
Sincerely,
Gary
Gary, I use a 1/4" drive 12mm universal socket with a approx. 12-16 " extension and ratchet handle. The 1/4" drive stuff is great, I use it probably for 50% of what I do.
