'70 2.2T engine: How to improve power and torque
Hi guys.
I have read some threads about this and have drawn a first conclusion I want to share with you. My objective is to improve torque in low and mid revs, and power at high revs (target 160 hp aprox)
I want to rebuild my original 911/03 2.2T engine, with the following:
* 89 mm JE pistons 9,8 CR
* Solex Cams
* Rejected Zeniths
* Original heads and crankshaft
* Lightweight flywheel and clutch
What do you think about?
Should I change the distributor?
Thanks in advance. Cheers.
