WTB: rubber USED oil lines (72/73) and various clamps
I'm looking for the soft factory oil lines that run between the engine and oil tank and oil tank and front oil cooler. The more used and leaky the better, but the threads need to be o.k. I'm looking to make up my own set using the factor ends. Get rid of something you'd probably throw in the trash anyway.
I think 66-71 are the small I.D. (18mm) lines. I need the 72/73 lines, which have a larger I.D. (22mm). Post-73 may also work...
These are available new through Stoddard for a reasonable price, but I figured using the old ones would be just as good.
Also looking for the clamps (40mm and the smaller size).
Thanks.
