901/01 engine parts FS
I am tearing down a 901/01 longblock this weekend.
I will have the following cleaned and ready to ship next week:
Upper valve covers-901.105.115 $75
On engine oil cooler, 911.107.041 non threaded-100
heads-901.104.306.2 $150
cam towers-901.105.111 $100
cams-901.105.134(133)-$150
rockers-75 full set (including shafts and adjusting nuts etc.---- sold pending payment
p&c-300
rods-100
wrist pins-50
oil pump-75
case & intermediate shaft-900
sump plate-25
Chain boxes-901.105.101(102) $100
Chain box covers-901.105.106(105)-$40
Mechanical tensioners-901.105.519-$125
Misc. hardware, just ask.
Crank $100 I will take if it's a stdor 1st under CW.
Richard
I'll take the crank and rockers - have sent you a PM
Andrew M
In line for crank and rockers.
Thank you,
Leonard
hello ..can use crank rods towers cams and matched rockers, please, if available, and will deal for the lot!
kind regards
Crank and rockers are sold.
Does the motor mave center lube cams ot standard splash lube?
I'd be in for the towers and cams if they aren't sold and are center lube.
I also want the chain boxes and covers and oil lines if they are the original braided steel ones.
Sorry for the delay Guys,
I should have it apart by tonight and will post up pics and confirm with everyone then.
D
Updated for PN's and added a few items.
10 Attachment(s)
