'68 S Aluminum case, short block, transmission
I have a aluminum '68S motor and non-matching 902/1 transmission sitting on a pallet waiting to be mated to a early S or perfect as the drivetrain for a T/R clone. Engine type is 901/02 and the engine serial number is 4080226. It is all correct original early S (heads, pistons, cams, crank, ect.) and turns over freely by hand. I would be willing to tear the motor down and sell the aluminum engine case for $2,500.00; sell the short block for $6,500.00; or sell the short block together w/ the transmission/cluch/flywheel for $7,800.00. ALUMINUM CASE SHORT BLOCK AND DISTRIBUTOR ARE NLA
I do have the distributor off this engine and would like to get $300.00 for it. The IDS carbs, manifolds, and linkage would be $2,500.00
In addition to the above, I would also like to offer a complete magnesium cased '68S engine (serial #4081109) for sale if there is someone out there with a chassis to mate it up to.
Thanks, John
Email to: jpnorthwood@aol.com
