3 Attachment(s)
1973 T 2.4 Oil Pressure sender mount.
New request, I’m helping a friend with his 1973 T CIS, and need the oil pressure sending mount that is a one year only “skinny” model vs the later wide mouth.
Attachment 458318
The skinnier one allows for the oil feeder for the entsioners to align perfectly.
Attachment 458317
The one we have has a smaller hole for the banjo bolt, which we could drill out, but wanted to check with you wonderful hoarders first!
Here the two are side by side. We need the skinny pressure mount with the larger banjo hole than the one we have. Should we just drill it out and put a washer notch in? There isn't a lot of edge material left if we do. Thank you!
Attachment 458319
