rebuild kit for '66 'S' calipers ?
do I use the rebuild kit for regular calipers to rebuild my 'S' calipers? as I understand it the early 'S' calipers were regular ones with a spacer in the middle to allow for the vented rotor. this would indicate that I can use the regular kit. any thoughts/help much appreciated. Don.
Standard calippers vs S-calippers
Is it possible to transform standard calippers for solid discs to the S-type for vented discs? And if this is possible f. ex with the earlier mentioned spacers, will vented discs fit on the car without further modifications?
I have a standard 1967 911.
