10 Attachment(s)
FS: Used ST Mahle long stroke P/C Set
A still usable set of Mahle 86.7mm Pistons/Cylinders with pins assembled and ready to install. Cylinders have been replated. Rings are new from Andial. See specs. Asking $1800
Cyl diam 86.73mm
Pistons diam 86.62mm
Pistons with pins Wt. (gms)
1>496 2>494 3>496 4>496 5>496 6>497
ring lands
1> .004" 2> .006 3> .004 4> .004 5> .005 6> .005
ring gap None greater than .016" (all .013-.016)
Pictures have shadows. I can retake if you need to see more.
Matt
reference numbers/plating
The cylinders say MAHLE E on one side and on the other they have 85ZN2A!+W1. The cylinder are also numbered 1 to 6
The tops of the pistons have 86.65 stamped in the tops (very small). The piston tops also have a capital E stamped into them with some very tiny numbers stamped next to or around the E. The tops also have a more prominent number or two stamped in to them. I can try to shoot pictures if you like.
I have been asked if these were plated for cosmetics so to clarify....These were sent to US Chrome in Wisconsin to have the bores re-Nikasil plated and refinished. The pistons and the outsides of the cylinders are cleaned but have their natural finish.
Matt
