5 Attachment(s)
Early 67 S weber 40 IDA "S" carbs and manifolds FS
These just came off my racecar, so they are choked and jetted for a hot 2.2 S engine. I rebuilt them 20 "race hours" ago. Apparently the first 500 1967 911 S cars wore these before the transition to weber 40 IDS carbs. If you have one of those early cars, these should be on your engine...if originality is important. Included with the carbs is a pair of date stamped 67 die cast manifolds. If you have any questions as to whether these are correct for your car, or if you need to determine how these should be choked/jetted, I would contact Paul Abbott at Performance Oriented
http://www.performanceoriented.com/new-page-1/
I can re-choke/jet the carbs...but they are being sold as-is. I also have available the uprights, crossbar and drops as well as the throttle bellcrank, and trannie to bellcrank linkage.
Asking $5k obo plus linkage.
Speedo
