FIRST 911 S brake calipers? ID and price check
Hello,
I have two questions about the brake calipers that were installed on my car when I bought it.
I know these calipers are not correct for a 1964.
I carefully read this excellent thread:
Vintage 911S Caliper Restoration.
The calipers I have could be the ones that Porsche installed on the first 911 S
- Could you please tell me if I am right?
- Do you have any idea of the market price for these parts?
See posts #2 and #3 for details / pictures.
I have also the vented rotors.
Philippe
9 Attachment(s)
ID and price check : REAR 911 S brake calipers
Hello,
Questions about the REAR brake calipers that were installed on the 300090 when I bought it.
Could you confirm that this rear brake calipers are the ones that the factory installed on the first 911 S?
https://www.early911sregistry.org/fo...l=1#post344500
Thank you.
Philippe
Rear brake calipers:
- 38mm piston diameter
- 7M fasteners
- 10mm spacers (10.6 mm)
- References / cast numbers:
- ATE 3 G + ATE 19 G
- ATE 2 G + ATE 24 G
- Others: see pictures
Attachment 596837
Attachment 596838
Attachment 596839
Attachment 596840
Attachment 596841
Attachment 596842
Attachment 596843
Attachment 596844
Attachment 596845
See also: Front brake calipers
9 Attachment(s)
ID and price check : FRONT 911 S brake calipers
Hello again,
Now: questions about the FRONT brake calipers that were installed on the 300090 when I bought it.
Could you confirm that this front brake calipers are the ones that the factory installed on the first 911 S?
Thank you.
Philippe
- 48mm piston diameter
- 8M fasteners
- 7mm spacers (7.3 mm)
- ATE 3 + ATE 251
- ATE 6 + ATE 251
Attachment 596848
Attachment 596849
Attachment 596850
Attachment 596851
Attachment 596852
Attachment 596853
Attachment 596854
Attachment 596855
Attachment 596856
See also: Rear brake calipers
