Do these both share the same tunnel hold down tabs ?
Only see one set (2 tab locations) and thought for the brake line .
So what holds the Speedo cable in tunnel
This is a 71
Thanks for assistance
Frank
This is a 71
Frank
Brake pipe is located in metal straps with rubber isolators. Zip ties hold the speedo cable away from moving parts in the tunnel.
Thanks ,got the brake line ....
so what do the zip ties for the Speedo attached to ?
Frank
Zip it to the brake pipe, which is on the passenger side of tunnel, not tight, just enough to locate it.
Thanks again for followup...
Will do
