Cleaning out the garage and found these they are SWB may be '67-'68 calipers. Any help is appreciated.
For rebuild. Price is $300 for the pair plus shipping and fees.
Front or rear? Have a pic. Of the opposite side of the attachment bolts? If they are swb S rears, I would buy!...,, Cliff
This a rear swb S caliper.
Hi Cliff, let me know if this helps. Thanks.
looking for the allen,torx type screws opposite the hex nuts.....
More pictures.
The correct screw heads are RIBE a.k.a. polydrive. Hard to find unless you have some core calipers to rob.
The pictured calipers have regular inhex head screws. I'm not sure when they changed but I don't think those are correct for that vintage caliper.
Those calipers are SWB non-S rear calipers. No spacer between the halves. The piston size will be 35mm vs 38mm for the S variant.
andy
Back up for sale.
The bolts and nuts are correct for those calipers. The fronts use Ribe the rears are plain nuts. You are correct in stating they are NOT S/L calipers and they do, in fact, have 35mm pistons and not 38mm pistons.
Jim
PS: I hope the buyer is not expectiong S/L calipers.
