Hello everyone,
I'm in need of an original ignition coil for my '66 911. I believe the correct part number is 0 221 102 026. Thanks for any and all help!
Sincerely,
Lee
302340
Hello everyone,
Sincerely,
Lee
302340
i have this blue one..i am fairly sure it was from a 65
Lee
I have one with that part number however I have no idea if it works plus I am in the UK so may be better trying closer to home.
Hi guys,
Thanks for the responses! PM coming to both of you.
Lee
302340
Close, we have a NOS 0221 102 042
Bantam's coil is correct. The other is a much later 027 "blue" coil with an internal resistor, would be a correct aftermarket item in the late 60s (see date code on bottom)
however. . .
Lee,
What is the production date of 302340? I think that a number in that range is 1965 production, so you want a screw-top coil, not a spade top.
Hi John!
First off, thanks for all the information you've posted with regards to the electrical systems on the early 911s! I've learned a lot from your posts! And your 911 is simply gorgeous!
I believe 302340 was built in September of '65. Right now I have an aftermarket coil/system (Crane Fireball system) in 302340 but I'm trying to return the system back to original. Any help is much appreciated! Do you know why some Bosch coils have the spade terminals and others a nut/bolt connection? If Bantam's coil is the correct version why does his coil show the spade terminals? Or am I confused about something?
Much thanks!
Lee
302340
Still looking! Dave's coil is on the way but not original, and Tim is unsure his is functional. Thanks much!
Lee
302340
Does anyone have experience with this coil for early 911?
http://www.ebay.com/itm/150746655692...84.m1423.l2649
