4 Attachment(s)
FS: Refurbished BOSCH H1's
** SOLD **
** Price reduced to $1,700.00 **
This is a great set of H1's. If it's possible to be "almost NOS" these are almost NOS.
It's always interesting to inspect these when they come in. It's obvious that this pair was removed from service when they were almost new due to a problem with the high beam adjustment. The rubber had broken that mounts a critical component which would have made it impossible to adjust them correctly. It's evident that that created a lot of frustration as the heads of the adjustment screws were ground out and the high beam reflector was wedged between the low beam reflector and the housing. After a fairly simple repair and a thorough cleaning I reassembled things and ended up with this almost NOS set.
The reflectors are in perfect original condition both front and back with original identifying stickers. The original chrome trim rings are not a perfect 10 but I rate them at a 9.8. The lenses may be new because they are perfect - lettering on the inside of the lens. New lens and mounting gaskets, two original adjustment screws (the long ones) and six new proper chrome plated adjustment screws, new proper chrome plated fender mounting screws, new 100w and 55w bulbs.
Attachment 368084
Attachment 368082
Attachment 368083
Attachment 368081
Even though I restore a lot of early lights I still really appreciate originality.
Price: $1,750.00 plus shipping.
2/20/16: Price reduced to $1,700.00
