Testing some auctions on some parts at PCA!
Testing some auctions on some parts at PCM!
https://www.pcarmarket.com/auction/w...3-carburetors/
https://www.pcarmarket.com/auction/1...1-s-crankcase/
This was sold at BAT just some weeks ago! but it was a bidding war in the end! my reserve is in the normal price believes.
https://bringatrailer.com/listing/cr...2-0l-flat-six/
9 Attachment(s)
68S case prepared for 2,5 L/2,7/2,8L RSR and a pair of Weber 46IDA
Attachment 599000Guys if I don't meet the reserve on the auction then I will sell straight out here later. The intermediate shaft is the original for the case.
But if somebody likes to run thrust bearings for the Intermediate shaft so you are able to run steel gears I can provide that. Intermediate in the sale will work fine, it depends on the type of engine you are building.
Attachment 598992
Attachment 598993
Attachment 598994
Attachment 598995
Attachment 598996
Attachment 598997
Attachment 598998
Attachment 598999
Attachment 599001
3 Attachment(s)
Crankcase- 68 S prepared 2,5 L 2,7,L,2,8 l ST/RSR and Weber 46
Crankcase- 2,5 L,2,8 l ST/RSR and Weber 46
Crankcase and shaft 7,900:- USD + shipping
Weber 46 IDA 7,900:- USD + shipping
Some gents have askt about this! just to clarify this, all threads for bolt holes are perfect, here are some pictures from the outside ! as you can see, there are no cracks, everything is very original and only cleaned with water after many years in storage
The current configuration of the Weber 46 set includes the following specifications:
Venturi/Choke: 38 mm
Main Jet: 170
Air Corrector: 145
Emulsion Tube: F24
Idle jet: 60
Pump jet: 40
https://www.youtube.com/watch?v=65U4...&ab_channel=MB
Pm for more pictures .
Attachment 599792
Attachment 599793
Attachment 599794
