Throw out bearing
My throw out bearing seamed rough so I removed it and cleaned/flushed it with varsol. It's actually pretty smooth now, tight from side to side and maybe .015" play front to back. Is it possible to just re-lube this and call it a day or should I change it. 68, 901 trans.
considering the amount of work required if it doesn't work, I'd replace it to be on the safe side. From prior experiences, I would never reuse the old throw out bearing when replacing a clutch. Don't forget to resurface your flywheel too.
Here's the thread I was referred to when I asked the question a year ago:
http://www.912bbs.org/vb/showthread....earing-Rebuild
Guess us 912'ers are just cheapskates, as well as 912 being one better than a 911....
Adam912.Out.
'66 912, 498K miles, 2.2L of light weight T4 fun!
