Engine Gurus...Advice Please
Time for a little fun with the engine. I'm seeking out some wisdom. Got a 2.7 Weber carbed engine in a 71T.
What is the recommended fuel pump (mine is spewing gas on the ground) and most importantly what's the best psi for this setup that will give decent fuel economy (best I can get and always use is Sunoco 94...cdn stuff).
I'm planning on silicone valve cover gaskets and switching from mechanical to pressure fed tensioners thus new timing chain cover gaskets as well. What's the current concensus on which gasket set is best? Silicone? Paper?
Hope to deal with this in the next couple weeks so need to begin gathering supplies to do it right. Any suggestions or advice is greatly appreciated. :D
