7 Attachment(s)
FS: 911 Steering Wheel Extended Hub (901.347.081.05, 901.347.082.11, 901.347.082.73)
These hubs were never sold separately but only found when ordering a new car (Option 416) or buying a complete steering wheel assembly.
- PET 65-68 911 Fig. 4-03-10, #14) 901.347.082.11 Steering wheel, wood with elevated hub, 30mm, -67 Qty: 1
- PET 65-68 911 Fig. 4-03-10, #14) 901.347.082.73 Steering wheel, leather with elevated hub, 30mm, -67 Qty: 1
- PET 65-68 911 Fig. 4-03-10, #14) 901.347.082.11 Steering wheel, rubber with elevated hub, 30mm, -67 Qty: 1
The OEM hubs required:
PET 65-68 911 Fig. 4-03-10, #(15) 914.347.832.00 Contact pin, for elevated hub SS: 91434783201 Qty: 1
PET 65-68 911 Fig. 4-03-10, #16 901.613.325.05 Cancelling ring Qty: 1
PET 65-68 911 Fig. 4-03-10, #16- 900.269.006.07 Countersunk-head screw, M4x8 Qty 2 NLA
PET 65-68 911 Fig. 4-03-10, #17 900.028.015.01 Spring washer, B 18 (for shaft) Qty: 1 SS: N 012 239 1
PET 65-68 911 Fig. 4-03-10, #18 900.078.007.02 Hexagon nut, M18x1.5 Qty: 1
PET 65-68 911 Fig. 4-03-10, #19 901.347.823.01 Rubber cap Qty: 1
PET 65-68 911 Fig. 4-03-10, #20 901.347.803.00 Cap Qty: 1 NLA
The original extended hub wheels had 30mm spacers that were inserted between the hub and the steering wheel before being riveted together to form a single assembly.
These new parts combine both the hub and the spacer into a single part.
Features:
* Stronger and faster to install than separate hub spacers
* Pre-finished in satin black
* Lightened for a 36% weight loss
* Includes the often missing, NLA top cover.
Material: Aluminum, 6061-T6
Finish: Ra 12µm (As machined)
Coating: Anodized, Type II, Class 2 (Black)
Weight: 503.06 grams (36.1% weight loss from OEM parts)
These assemblies come with all the required fasteners:
* Hub-Wheel: ButtonHead, Socket Screw, Steel, 10.9, Zinc, M5x12 Qty: 6
* Hub-Turn Signal Cancel Ring: Flat Head Machine Screw, SS, M4x6 Qty: 2
* Hub-Horn Support Ring: ButtonHead, Socket Screw, M3x10, SS Qty: 3
They require the purchase of a 30mm longer horn contact pin: 914.347.832.00, SS: 91434783201.
The price is $142.12 each.
Shipping within the US is by USPS Priority ($10.40). International shipping is available but requires the purchase of insurance.
Other available parts:
Key Words: 901.347.081.05, 901.347.081.15
