65 Fuel Gauge Question - Stumped
I recently finished restoring a December build 65 911 only to have it run of of fuel with half-tank showing on the gauge. I replaced the sender with a known good one only to show the same faulty reading (full on the gauge with the tank only half full). I plugged in another gauge only to get the same faulty reading. What am I missing? The gauge will drop from full to half when in fact the tank starts out only half full. I do notice that with other cars the fuel level needle fluctuates on hills and through corners, whereas this needle is steady going downward as fuel is consumed -- regardless of the sender used. Thanks in advance for any help.
