46 IDA Weber's w 911R Magnesium Tall Manifolds-PRICE DROP
I am selling this pair of carbs and manifolds.
The Good: Carbs are really clean with clean float bowls. Manifolds are exceptionally clean with no corrosion in the mating surfaces where many get eaten up. Very nice combo.
The Bad: Carbs are missing emulsion tubes (fairly cheap to buy). Air horns need plated. One manifold has two holes drilled for vacuum fittings. One is in the thick upper flange and the second is in the middle throat. These can be simply pipe plugged or you can take it to a welder who specializes in magnesium.
Price lowered to$4,400 for the pair OBO. I will only consider splitting them if I find two interested parties.
Please ask if you have additional questions.
http://forums.pelicanparts.com/uploa...1342998650.jpg
http://forums.pelicanparts.com/uploa...1342998673.jpg
http://forums.pelicanparts.com/uploa...1342998716.jpg
http://forums.pelicanparts.com/uploa...1342998755.jpg
http://forums.pelicanparts.com/uploa...1342998776.jpg
