Could someone with a removable speaker grill for their dash please take a measurement and let me know what the length, width, and corner radii are?
Thanks in advance,
-Mike
Thanks in advance,
-Mike
Mike, what year are you interested in - '69 is different from '70 thru '73 as I understand it. I can do the '69.
Bill
Ah, thanks Bill I was unaware there was a difference. I need the dimensions for '71. Thanks for setting me straight and trying to help.
-Mike
I have one in my hand. It is the 10 inch long version with the straight hole pattern similar to below(as opposed to the tapered pattern). I'm pretty sure it's correct for my '73.
It's hard to get a good measurement because the edges are slightly tapered- that is the top side is slightly smaller than the bottom side probably due to shrinkage. On the top it measures 10 inches long, 4 9/16 wide and the radius of the corners is about 1 5/16. Hope this helps.
BillM
Hole pattern:
O O O O O O O O O O O O O O O O O
etc
Thank you Bill. That will do nicely.
-Mike
