2.2L 911 Motor - Complete, ready to run Price: $3425
Engine is from a 71T (2.2L) and has carbs (Zeniths) with linkages, oil tank, cdi panel, regulator, coil, cooler, alternator/fan. Missing carb airbox and engine harness. Leak down are all 6 are between 15 & 20% at 100psi. A compression test before motor was removed showed all cylinders where in the 127 - 130 range, the motor has not run much in the last 3 - 4 years and started and ran fine (didn't even leak oil). Has brand new SSI on one side. Also have clean muffler (not pictured)
http://images.thesamba.com/vw/classi...ix/4118505.jpg
http://images.thesamba.com/vw/classi...ix/4118506.jpg
http://images.thesamba.com/vw/classi...ix/4118507.jpg
http://images.thesamba.com/vw/classi...ix/4118508.jpg
