10 Attachment(s)
Repa 72-73 retractable Seat Belt Set #3
++++++++++ SOLD ++++++++++
Up for sale is a Repa seat belt set with nice retractors, good original US 5-bar black webbing and receivers.
The receivers are not the original hard to find, very expensive receivers, but they are something that resembles that quite well.
While building the ST harnesses I had to replicate the small plate that is also used on the early retractable seat belts and I had a couple more than I could use.
I also had some VW Repa rear seat belts and I have combined the two with double folded webbing and had it professionally stitched, so that it is safe to use.
This way you can still use the original mounting hooks that are on your standard seat. (or sport seat frame mountings)
The retractors in this set are the later type without screws, and they are a left an right one. The B pillar guide is the later Repa that has been freshly powder coated black and comes with the plastic repa cap that goes over the bolt. The repa tongue is in great condition, it's the type that had an extra plastic guide on the back that I have gently cut away to resemble the originals. Webbing is cleaned before mounting and the plate is also one of my new replica plates, with fresh zinc and webbing is re-stitched with correct repa stitching by a certified seatbelt stitcher. there are no labels on the belts, but you get two labels of choice (72 or 73) that you can stich on yourself with any sewing machine. (or by hand)
