5 Attachment(s)
FS: 380mm Steering Wheel w/ Horn Pad
This is a nice hard rubber 380MM wheel taken from a 914/4 and "modified" to fit a 911 (holes tapped/countersunk on back side for 911 signal cancel ring).
The P/N is 914.347."XX".11 (the 3rd set of numbers are lightly struck and impossible to decipher) my guess based upon the sunk hub on the front and the sunk shaft end is that it is a "914.347.805.11" wheel. Date code is "73 9".
The wheel has original paint on the spokes and the rim is in nice condition. You just need to transfer the rubber cup and 911 turn signal cancel ring from your old wheel. Nice "driver" or candidate for a double wrap.
$300 for the steering wheel and the horn pad plus shipping. Thanks
