Requesting recommendations for a new muffler for my '72 911T.
My preference is for one that looks and sounds original, but one that will not become unsigthly due to rust.
Does anyone make/sell a good quality and fit stainless piece?
Forgot to mention that I've researched the board's archives, and have read that the S/S Monty is highly rated by many, however, it reportedly has a negative affect on MFI's low and mid-range performance? This wouldn't be ideal for me as most of my driving is around town where I want the low and mid-range power and torque.
Suggestions?
How's your budget? I understand that stainless Leistritz (sp?) is still available, but $uper $pendy. A better financial option may be stock, but have it ceramic coated before installing it? I've never found a "heat resistant" rattle can paint that lasted long.
any leads on where I can find more info on the S/S Liestritz?
You might send Chuck Miller a PM. If memory serves, it was he who mentioned them in an earlier muffler thread that I can't seem to find now. $uper $pendy if I recall...well over a grand. Anyway, Chuck might know.
Hi:Quote:
Originally Posted by 87-930-palmbeac
Monty makes a specific muffler for MFI-equipped cars. The baffling is different. Works great,.....:)
"Monty makes a specific muffler for MFI-equipped cars. The baffling is different. Works great"
Thanks, sent you an email requesting more info.
Thanks for the tip, Steve! Anyone else want to share their experience with Monty's MFI-specific muffler?
I spoke to Monty about this (he's based in Oz) and he refers to it as a 6 baffle muffler. I had another monty on my 2.7 MFI which had BAD flat spots below 4000rpm. I swapped mine for a factory Leistritz that was on a car I bought and they completely went away (engine dyno'd at 201 rw hp).
I guy I know with a real 73RS was having the same problem and he had the 6 baffle monty fitted and his problem also went away. It has a slightly bigger outlet than a standard muffler (but not a big ricey drain pipe) and sounded pretty cool. I would have bought one if the L'z hadn't fallen into my lap.
I've since converted the L'z into a Rallye syle (2 centre outlets with removable caps which i'm fitting next weekend).
My old monty went onto a 2.4CIS motor and worked like a charm.
Hope this helps.
Here's my solution. Dansk original from AutoFarm. Works well. Sounds great.
