A friend of mine has an original 2.7 RS engine that was sourced in the Netherlands many years ago. Would be interesting to find out whether the car it came from still exists. Is there a such thing as an international Carrera RS register?
Einar
Einar
The engines and matching VINs are listed online and in the RS book.
Well, there was the well regard book Carrera RS that lists all chassis numbers, etc. That might help start the search off.
VIN / engine combos listed here if you want to reverse lookup the VIN via Google search or attempt to use early S's search function:
http://www.lehrenkrauscafe.com/vbfor...ad.php?p=66656
Disclaimer: Not vouching for accuracy of the list, just showing you the data is out there
If you really want to get good, accurate, and fairly quick info....post the ENGINE # here, as in the thread below:
https://www.early911sregistry.org/fo...highlight=1248
Thanks, all. It appears the engine most likely is from a 1974 model. Not that sought after then, I suppose.
Still a great motor
