6 Attachment(s)
Twin plug distributor
Does anyone know which manufacturer made the twin plug distributor as pictured? Was told it was made in Germany and was pulled off a 930. It currently has a CCW rotation drive gear and fits 30mm engine cases. It has the upper sealed bearing for added support on the shaft plate. Any info is greatly appreciated.
1 Attachment(s)
Additional phot of the upper sealed bearing on shaft plate
3 Attachment(s)
It looks very much like the Andial Distributor on my 930
It does look like the one you have but just a longer version. It does take the Andial distributor cap. Hoping someone can help decider the numbers stamped on it and confirm the maker/manufacturer.
