Mahle PS84-001 2.2S Piston / Cylinder Set
Selling a complete Mahle Motorsport 84mm piston / cylinder set that’s normally advertised for the 2.2S but can be used in 2.4 liter cars. The set is unused and still in the original box. Set includes 6x pistons, 6x cylinders and all the rings.
I needed a higher compression piston set for my build (due to the volume of my twin plug heads) and decided to also go with 85mm cylinders as well. With that, the kit is surplus to my needs.
Asking $3400 shipped in CONUS.
Stretch
