Hi:
You can tell I am a newbie... I can't find where the oil pressure bulb sender is supposed to go on my 67S. I have a new one already which I need to install, but... :confused:
Any help?
victor
Hi:
Any help?
victor
Maybe I'm not quite understanding your question, but your car doesn't have an oil pressure light, it should only have the oil pressure gauge. The sender for that is located on top of the engine, next to the oil breather housing near the flywheel end.
Thanks! Yes, no light, I was refering to the oil pressure gage.
Victor
S`cuse but there`s a sender built into the side of the oil tank, up inside the rear wing. Isn`t that responsible for the oil level signal ?
Mike
Ah, so, ok, the sender in the oil tank is the oil level sender, not the pressure sender, makes sense really :o
Regards, Newbie Mike.
You hang in there newbie Mike, everyone learns something new on these cars every day, (including the experts)
