FS: VDM 380mm Steering Wheel w/ Horn Pad
This is a nice VDM hard rubber 380MM wheel taken from a 914/4 and "modified" to fit a 911 (914 hub removed and holes tapped/countersunk on back side for 911 signal cancel ring).
The P/N is 914.347.804.11 (the"11" has been struck over "00") and the date code is "73 9".
The wheel has original paint on the spokes and the rim is in nice condition. You just need to transfer the horn plunger and 911 turn signal cancel ring from your old wheel. Nice "driver" or candidate for a double wrap.
$350 for the steering wheel (plus $50 for the horn pad - will not sell pad separately) shipped CONUS. Thanks http://forums.pelicanparts.com/uploa...1406049132.jpg
http://forums.pelicanparts.com/uploa...1406049145.jpg
http://forums.pelicanparts.com/uploa...1406049156.jpg
http://forums.pelicanparts.com/uploa...1406049168.jpg
http://forums.pelicanparts.com/uploa...1406049182.jpg
