Motor assembly continues. (1967 911). I bought/installed the updated idler arms, that are wider on the pivot than the originals. Accordingly, my understanding is that no 'spacers' are required when using the (narrower) 930 tensioners. But I notice 3mmm space between tensioner and idler arm. In other words, the idler arm has 3mm of axial travel. Doesn't seem right, or is it?? Thanks
