6 Attachment(s)
915 shift housing with FSS and Gate Shift kit
This is a factory short shift (FSS) kit and Seine Systems Gate Shift kit installed in a rebuilt early 915 shift housing. Both are brand new. The Gate Shift kit comes with a factory warranty. Bolt in and you're ready to go.
The FSS kit provides a 24% reduction in gear-to-gear throws, and the Gate Shift kit adds spring tension to the 1st/2nd gear positions. In neutral, the lever is centered in the 3/4 shift plane. See the archives on the many favorable comments for this shifting accessory.
The GS lever tab is attached to the lever with a clamp which can be tack-welded in place following final adjustments in your vehicle.
The parts have been modified per the procedures described here:
http://www.seinesystems.com/ShiftHousBluPrint.htm
The regular web price for this combination is $375.00 with the factory shifter. For the same price, you get a brand new factory short shift kit. The shift housing shows some cosmetic defects despite the polishing (see photos). If you're going to use the shift boot (rubber or leather), this will not matter at all. In fact, I'll include a rubber shift boot with purchase. Functionally like new.
Works with 901 gearboxes with a minor modification.
Sherwood
Seine Systems
