hello im working on a 73 911 some one else started to put together after paint and body work.
park light work when headlight switch is pulled to first position however when i pull the switch to 2nd position no power at any of the 4 fuses for left and right headlamp the park lights are working on both positions all the wires are conected on the switch all fusees are good no power either side of fuse
Thank you for helping me out.
