Distributor Problem 1965 2.0L Engine
Hi -
I just had my all original 1965 2.0L engine rebuilt and am now having major problems with the distributor. It starts well and startup begins around 2000rpm and then falls to below 1000rpm for idle. The problem is when I raise the idle to say 3000rpm and then let off the throttle the idle raises to around 3200rpm and stays there no matter what I do. I then took it out for a short drive to see if it might resolve this isue but it only got worse. As I drove the car and incresed the idle to 4000rpm and let off the idle shot up to 5000rpm. Then as I drove again up to 5000rpm and let off the idle shot to over 6000rpm and would not come down. Seems to me that the distributor just died or something is set wrong. I know these early distributors were a problem and were quickly upgraded by Porsche. However, this early 300XXX 911 has been restored to original showroom delivery.
FYI - The distributor worked fine before the rebuild.
Anyone ever had this experience?
Thank you
