If you need a smaller steering wheel that looks stock, this 914 wheel will do the trick, using the 911 horn assy. No cracks in plastic at all $399 obo
Old old story (see threads) Won't work with 911 (if turn signal cancel is to work) w/o some modification. Thanks.
-Allen-
If interested, check out the old threads
It's not just the turn signal ring. The shaft of the mid year and later 914 has a slightly different bevel where the wheel sits than a 911 or early 914 wheel. Those later 914 wheels are $50-75 all day long.
