Starting her up, any advice?
The time has come for me to try starting the engine. I've scoured
this board and PP and here's what I plan to do:
- check tensioners
- drain oil
- replace oil with thin oil to flush
- remove plugs
- put a little oil in the plug holes to lubricate the rings
- remove valve covers
- lubricate valves
- turn over by hand
- turn over with starter, check for oil pressure
- drain oil
- new oil filter
- fill oil with quality replacement oil
- attach fresh fuel container (tank is currently out of car)
- new plugs
- ignition!
Is there anything I've missed here? This is going to be a big day for me
and the car.
andy
