I need the base plate to install the MFI pump on my 2.2S engine. I think it is similar to the one in the picture. I also need the upper left valve cover or a pair(upper left/right) with no pitting and they must not be twisted.
Bump, I still need the cover/covers! Alu. are probably best?
John I have a set of early Alu. upper valve covers if interested I can send you some pictures
Yes Tony, please send me some pictures to:
jlands2"at"online.no
Thanks for replying!
I have 2 styles avail one with 901# the other 911#
small difference is early 901 one has a 16mm hole in the center and base is level
the other is identical like the one you have pictured.
let me know when you need one, I have several avail!
