9 Attachment(s)
Refurbursed / restored early door strikers (or service)
I spent the last month trying to get this process down just right. FINALLY!
These are the bright zinc strikes.
Check out the plating on the inside- it is not dull!!!
I will have Yellow and blue chromate strikes as well.
These are original strikes that are stripped and plated.
New nylon inserts are added as well.
I will post pictures later.
I have or will have matching sets to sell.
I don not have many sets.. these are harder to come by than I had originally thought. Still working on it.
67-2L - 68-2R
67-3L - 68-3R
67-4L - 68-4R
I will have some mounting bolts and shims as well.
I can also re-plate you original door strikers if desired.
The newly plated strikers are $250 a matching and $215 if you send in you originals.
I can also plat your original door strikers and return them to you completed. $200 which includes the plating in any color and new nylon inserts.
shipping is included in CONUS.
Before and After
Attachment 552253
Attachment 552254
Attachment 552255
Attachment 552256
Attachment 552257
Attachment 552258
Attachment 552259
Attachment 552260
Attachment 552261
