Porsche Storage- Radiant heated floor- Need Your Help
I am petitioning our local zoning office allow radiant floor heating in the garage I am building.
Would like to hear all of the different pro's and justifications this group can come up with- and if you have any substantiations so much the better.
So far I am including:
-These generations of vehicles basically had no rust proofing, so any reduction in humidity is better.
-Radiant heating is ideal because of the movement of heat from bottom of the vehicle to the ceiling; helps move moisture away from the body of the vehicle.
-Radiant floor heating in winter can be a much more efficient way to heat a workshop.
I actually don't think I will be turned down, but in my letter I wanted to make sure I leave no stone unturned in my correspondence.
Thank you in advance,
