Hi Guys,
A friend is rebuilding his 66 911. If the rubber mounts in the support bar are "toast" is the ONLY solution replacement ($700)? or is there an alternative or work-around for this?
I've only ever owned 72s and 73s so the "easy" and cheaper solution with these years is not an option.
Your advice appreciated,
