10 Attachment(s)
Repa 72-73 retractable Seat Belt Set #2
+++++++++ SOLD +++++++++
Up for sale is a Repa seat belt set with nice retractors, good original US 5-bar black webbing and receivers.
The receivers are not the original hard to find, very expensive receivers, but they are something that resembles that quite well.
While building the ST harnesses I had to replicate the small plate that is also used on the early retractable seat belts and I had a couple more than I could use.
I also had some VW Repa rear seat belts and I have combined the two with double folded webbing and had it professionally stitched, so that it is safe to use.
This way you can still use the original mounting hooks that are on your standard seat. (or sport seat frame mountings)
The retractors in this set are the early type on with philips screws and one with slotted, and they are a left an right one. The B pillar guide is the bulky black coated version (These are the Autoflug type with the extra pimple on the upper side of the mounting hole, I do not have plastic caps for these), the repa tongue is in good condition, only a few tiny spots. Webbing is cleaned before mounting and the plate is also one of my new replica plates, with fresh zinc and webbing is re-stitched with correct repa stitching by a certified seatbelt stitcher. there are no labels on the belts, but you get two labels of choice (72 or 73) that you can stich on yourself with any sewing machine. (or by hand)
